Date/Time: Tue, 14 May 2024 01:48:03 +0000
Fast Scrolling back
View Count: 866
[2018-05-14 12:22:24] |
PaulC - Posts: 16 |
Is there an easy way of scrolling a chachart 2-3 days other than clicking and dragging? Tedious in 1 minute charts! Tank you |
[2018-05-14 19:04:19] |
Yes, you can use this particular command: Chart Menu: Goto Date/Time (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
