Date/Time: Tue, 14 May 2024 09:25:18 +0000
Is there an issue with Gain Capital?
View Count: 632
[2018-05-14 09:11:06] |
User735389 - Posts: 188 |
I'm getting an error on OpenEcry when trying to place a trade (Order was rejected... Provider Is Not Available) and the QuoteBoard is showing 0 for the spread
[2018-05-14 09:12:24] |
Okay, it sounds as though you are trading the Forex symbols. Yes those are no longer available through Gain Capital. You can trade the Forex futures instead.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-14 09:12:38
[2018-05-14 09:43:09] |
Do you mean forex symbols no longer supported by Sierra Chart through Gain, or not supported by Gain Capital itself?
[2018-05-14 09:47:42] |
Through the particular connection that Sierra Chart uses to Gain Capital, they are no longer supported through that connection. This was a decision by Gain Capital. Sierra Chart has no support for cash Forex symbols through Gain Capital at this time and there are no plans to offer that since that is a major work effort which we will not get involved with. We recommend having a look at other supported services like LMAX for Forex trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-14 09:50:19] |
Here is the information about LMAX: LMAX Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
