Date/Time: Wed, 15 May 2024 00:29:56 +0000
color code of the chart values
View Count: 567
[2018-05-14 08:39:40] |
johnnykf88 - Posts: 17 |
hi support team, i'm trying to create c++ study with, for example, "AC/DC Histogram". Its output values, as seen in Chart Values window (uploaded screen), come with green or red in colors. How may i capture or identify this color code in cpp apart from its value? http://www.sierrachart.com/image.php?Image=152628554697.png Thanks in advance. |
[2018-05-14 19:03:22] |
With that particular study, the coloring is based on the slope using the Subgraph Auto colouring setting. Therefore, you just need to look at the values and determine the slope. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
