Date/Time: Wed, 15 May 2024 16:34:34 +0000
How to Lock the Y Axis
View Count: 1383
[2018-05-14 00:31:08] |
User373489 - Posts: 9 |
Can you please tell me how I can lock the "Y" Axis on any chart, so that when I scroll through a time period the right hand side or "price axis" does not change? Thank you, |
[2018-05-14 09:00:58] |
Follow the instructions here for this: Chart Scale and Scale Adjusting: Using Fixed Values for Top and Bottom of Scale Range Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-14 12:21:32] |
When I select the Scale Range: User Defined with Auto Set, the chart goes black and the values are negative. It will not allow me to change the values unless I select a different option. |
[2018-05-14 16:56:29] |
Attach the chart you have this problem with, following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-14 18:59:33] |
Please see attached.
Date Time Of Last Edit: 2018-05-14 19:08:39
Chartbook5.Cht - Attached On 2018-05-14 18:58:51 UTC - Size: 53.49 KB - 260 views |
[2018-05-14 19:15:25] |
We cannot reproduce the issue and it makes no sense either for it to happen. We do not think this will matter but update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-14 19:15:48
[2018-05-14 19:20:09] |
Actually we think we know what the problem is, you need to select this specific command named exactly as it is from the Values Scale menu: Scale Range: User Defined with Auto Set. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
