Date/Time: Sun, 19 May 2024 10:31:45 +0000
TD Login
View Count: 995
[2018-05-13 15:08:53] |
User170575 - Posts: 221 |
Hi--cant seem to login---I am able to get into TOS with the user and password--it has been a while since I used this copy of Sierra---I did update it. Thoughts appreciated---THX. Cy HTTPS connection to apis.tdameritrade.com:443 (23) | Initiating close of socket by core. | 2018-05-13 11:04:47 TD Ameritrade | Disconnected. | 2018-05-13 11:04:47 Disconnected from TD Ameritrade. | 2018-05-13 11:04:47 HTTPS connection to apis.tdameritrade.com:443 (23) | Shutdown started. Waiting for graceful close. | 2018-05-13 11:04:47 HTTPS connection to apis.tdameritrade.com:443 (23) | Socket gracefully closed by remote side. | 2018-05-13 11:04:47 HTTPS connection to apis.tdameritrade.com:443 (23) | Closed. | 2018-05-13 11:04:47 TD Ameritrade | Connecting. | 2018-05-13 11:07:44 TD Ameritrade | Logging in. (Step 1 of 3) | 2018-05-13 11:07:44 HTTPS connection to apis.tdameritrade.com:443 (27) | Creating socket. Using TLS 1.0. | 2018-05-13 11:07:44 HTTPS connection to apis.tdameritrade.com:443 (27) | Connecting to IP: 216.105.251.201. | 2018-05-13 11:07:44 TD Ameritrade | Login Error: Login Failed | 2018-05-13 11:07:44 * TD Ameritrade | Login failed. | 2018-05-13 11:07:44 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-05-13 11:07:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-05-13 11:07:44 HTTPS connection to apis.tdameritrade.com:443 (27) | Initiating close of socket by core. | 2018-05-13 11:07:44 TD Ameritrade | Disconnected. | 2018-05-13 11:07:44 Disconnected from TD Ameritrade. | 2018-05-13 11:07:44 HTTPS connection to apis.tdameritrade.com:443 (27) | Shutdown started. Waiting for graceful close. | 2018-05-13 11:07:44 HTTPS connection to apis.tdameritrade.com:443 (27) | Socket gracefully closed by remote side. | 2018-05-13 11:07:44 HTTPS connection to apis.tdameritrade.com:443 (27) | Closed. | 2018-05-13 11:07:44 |
[2018-05-13 20:21:25] |
All that we can say is the TD Ameritrade system is indicating this: TD Ameritrade | Login Error: Login Failed | 2018-05-13 11:07:44 "Login Field" is direct text from the TD Ameritrade system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
