Date/Time: Sun, 19 May 2024 11:41:21 +0000
Problem Re-installing Intuitive SigmaTM Charts
View Count: 831
[2018-05-13 00:54:22] |
User300112 - Posts: 6 |
The first time I installed the Intuitive SigmaTM Charts, I followed the video instruction and all went well. However, the section to add "Regression Analysis Study", I could not locate the file "RegressionAnalysis.StdyCollct" within the Studies folder as there was no such folder that I could find as shown in the video. I then proceeded to delete the entire Intuitive SigmaTM Charts folder and re-installed again thinking I must have failed a step the first time round. The second installation has failed with a message box saying "Maximum number of retries encountered" and "Press Install to retry". I tried again and the same message appeared. I have attached a screenshot of this message and the installer log. Please advice what steps to take. Thank you. |
Private File Private File |
[2018-05-13 01:13:55] |
I then proceeded to delete the entire Intuitive SigmaTM Charts folder and re-installed again thinking I must have failed a step the first time round. The second installation has failed with a message box saying "Maximum number of retries encountered" and "Press Install to retry". I tried again and the same message appeared. This problem is now resolved. Try again:Software Download: Fast Update In regards to this you need to contact Intuitive SigmaTM Charts: The first time I installed the Intuitive SigmaTM Charts, I followed the video instruction and all went well. However, the section to add "Regression Analysis Study", I could not locate the file "RegressionAnalysis.StdyCollct" within the Studies folder as there was no such folder that I could find as shown in the video.
