Date/Time: Tue, 21 May 2024 21:10:35 +0000
show alerts in the charts?
View Count: 1627
[2018-05-11 22:38:08] |
User308138 - Posts: 17 |
is there a way to show my alert in chart like a line? i know i can use a horizontal linea but i like it to appear when im setting up a "add a symbol alert" menu |
[2018-05-14 18:25:24] |
Use the Color Bar Based on Alert Condition and set the Draw Extension Lines at Color Bar Value to Yes. The documentation for this can be found here: Color Bar Based on Alert Condition: Draw Extension Lines at Color Bar Value Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-14 18:36:26] |
but that dosent draw a line where my untriggered alert is..
[2018-05-14 18:45:17] |
Therefore, just use the Line study: Line And set an alert on it: Study/Chart Alerts And Scanning Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-15 01:11:31] |
yeah i know i can do that, but i would like to know if its posible by just stting up an alert by using "add symnbol alert" and make them show in the chart since its more easier to create an alert this way
[2018-05-15 02:08:14] |
No, definitely not.
[2024-03-04 12:35:26] |
User732858 - Posts: 3 |
would need to see levels where the untriggered alerts are. I have multiple alerts, some of them might be already triggered some not.
[2024-04-09 10:35:17] |
User840187 - Posts: 4 |
I use horizontal ray alerts and I like them a lot. The only problem is that - unlike symbol alerts - you have to leave all the charts open all the time. It would really be handy to be able to display/drag symbol alerts (a basic functionality imho). Date Time Of Last Edit: 2024-04-09 10:38:51
