Date/Time: Sun, 19 May 2024 18:59:31 +0000
Attached Trailstop
View Count: 625
[2018-05-11 14:58:49] |
User39772 - Posts: 311 |
If I use an attached trailstop with my order, is there a way to check in ACSIL, if the trailstop is still active or if is has already been canceled by other oders because sc.CancelAllWorkingOrdersOnExit = true; |
[2018-05-11 17:21:50] |
@sstfrederik - Posts: 404 |
remember the order id and use sc.GetOrderByOrderID to check OrderStatusCode
[2018-05-11 20:41:34] |
Yes, do what is described in post #2. Refer to: Automated Trading From an Advanced Custom Study: sc.GetOrderByOrderID Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
