Date/Time: Sun, 19 May 2024 15:10:45 +0000
Correct symbol for call spread?
View Count: 637
[2018-05-10 19:36:42] |
trader1 - Posts: 128 |
Hi, Is there a symbol that can be used to chart the price of a call spread using IB data with Sierra Chart? Thanks. |
[2018-05-10 20:06:13] |
Not a spread but individual options can be charted and then you can use the Difference study with them. Refer to: http://www.sierrachart.com/index.php?page=doc/IBSymbols.html#Option http://www.sierrachart.com/index.php?page=doc/StudiesReference.php&ID=3#Difference_-_Bar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-10 21:00:01] |
Thanks very much for the quick response. Can you please tell me which study would work for a straddle? I tried sum charts from a list but I am not sure if that is appropriate.
Date Time Of Last Edit: 2018-05-10 21:02:04
[2018-05-11 00:46:48] |
How is the straddle calculated? You may want to use this study: Combination Symbol Chart This study should give you enough flexibility to accomplish this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
