Date/Time: Sun, 19 May 2024 14:15:45 +0000
alert based on the number of times
View Count: 1101
[2018-05-09 19:17:09] |
02108 - Posts: 27 |
I'm trying to create an alert based on the result of the study Volume At Price Threshold alert V2. Ask volume Bid volume Difference is set to 100, then in every price level that the difference is 100 will appear the alert. But I want an alert if it happens this 3 times inside a candle, in 3 different price levels.I tried adding background color based on alert to insert a formula but I could not either. What formula do I need to put for it to have alert if it happens 3 times in a candle?I want to create the condition of needing to appear 3 times inside the candle to have the alert. Thank you |
[2018-05-09 21:03:15] |
We are going to add a new Study Subgraph to the Volume at Price Threshold Alert study to indicate the number of times the condition is true on the bar and then you can use that in an alert condition formula.
[2018-05-09 21:21:34] |
02108 - Posts: 27 |
Do you have any predictions for when this will happen? Thank you |
[2018-05-09 21:58:29] |
Within about two weeks.
[2018-05-09 22:16:18] |
02108 - Posts: 27 |
Thank you
[2018-05-10 15:40:09] |
John - SC Support - Posts: 31715 |
This feature has been added and will be in release 1744. We do not have a timeframe for when this will be out, but it is typically only a few days. Check the main website (https://www.sierrachart.com/) on the right hand side to see when the release is out. The information on this subgraph can be found on the bottom of this page: Volume at Price Threshold Alert V2 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-10 15:57:09
[2018-05-11 15:24:25] |
02108 - Posts: 27 |
today came out the 1744 version but still without this update?in the version notes there is nothing about the 1744 version.
[2018-05-11 17:08:39] |
It is not in the version notes, but it is in the release. If you add the study and look at the subgraphs, you will see a subgraph named Count of Alerts down at the bottom as SG59. You can then reference this Sungraph through the Study Alert Formula. To do this, follow the information here: Study/Chart Alerts And Scanning: Referencing Study Subgraphs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-11 20:16:32
