Date/Time: Sun, 05 May 2024 07:49:18 +0000
Quick Symbol change
View Count: 937
[2018-05-09 03:10:54] |
User183699 - Posts: 3 |
Is there a way to have a place to type in the control bar the symbol you want without opening up "find symbol" or a watchlist? I want to be able to type in a symbol and hit enter quickly.
[2018-05-09 05:53:54] |
There is a way to do this and it is documented here: http://www.sierrachart.com/index.php?page=doc/SwitchingSymbols.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
