Date/Time: Wed, 15 May 2024 06:58:18 +0000
Cancel Orders on Flat Position
View Count: 768
[2018-05-08 19:19:10] |
padddler - Posts: 10 |
Is there a global setting to "Cancel Orders on Flat Position", so I don't have to manually set this every day for every chart with a trade window attached. I understand what it does and want it always. If not, would it be possible to create a global switch to always have it on? Thanks, |
[2018-05-09 19:41:32] |
We will make sure this option is saved so you do not have to keep re-enabling it whenever the chartbook is opened.
[2018-05-15 17:24:45] |
I still have to keep re-enabling the "Cancel Orders on Flat Position" whenever the charbook is opened.
[2018-05-15 18:01:19] |
Any time we make a change in Sierra Chart, you would need to update after that has been released. So you need to update following the instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
