Date/Time: Sun, 05 May 2024 18:26:33 +0000
volume profile (Vpb) Questios
View Count: 678
[2018-05-08 14:15:35] |
User968625 - Posts: 256 |
I have a Flex Renko chart (4-2-3) and wanted to have a 30 mins Vpb on it for regular trading session (9.30-16.15) however I have two issues: 1- I can't seem o change the tick per volume to 1 tick (in another similar chat I can). I was wondering what setting I am missing that is stopping it from accepting the 1 tick. 2- For "Draw profile outline Enlosing bars": the high and low of the box is not at the high and low of the period (30mins), is there a way to make the high and low of the enclosing box at the high and low of the period. |
[2018-05-08 19:21:43] |
1. Refer to the documentation here for this: Volume By Price Study: Ticks Per Volume Bar 2. Provide an image of the chart showing this, by following these instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-08 19:22:14
[2018-05-08 19:36:21] |
Ok, thanks. for 2: once I corrected the chart setting to 1 tick, the enclosing works for high/low of the period.
