Date/Time: Sun, 19 May 2024 06:52:10 +0000
Hiding Individual Studies from a chart
View Count: 2970
[2018-05-08 13:24:55] |
User924725 - Posts: 26 |
hello, I have a chart with 4 studies, I would like to be able to hide individual studies, for example : from the 4 studies hide the 2 of them with a shortcut key that i assing, I am aware how to do hide all of the studies already. Also i am aware how to assing shortcut key thanks |
[2018-05-08 18:26:49] |
There definitely is no shortcut key for this. You can hide them directly from the chart by following the instructions here: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#HidingShowingStudy Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-08 19:35:25] |
i am aware of this , what i was asking is if i can hide 2 individual studies (from the 4)... at the same time. meaning that not having to go to one study and hide it and after that go to the other study and hide it ... etc etc chart with: study A study B study C study D shortcut key-------> hides BOTH C and D shortcut key-------> shows up BOTH C and D studies for example : at Analysis TAB -----> there is an option which can hide all of the studies in the chart. I would like to hide half of the studies in the chart ... meaning select which of the stydies i whanna hide with one click. Also I already have assinged a shortcut key to hide/enable all the stydies in the chart. Date Time Of Last Edit: 2018-05-08 19:48:09
[2018-05-08 19:41:40] |
The solution to this is to have two different Study Collections, each with the particular study configuration, including the Hidden state, as you require and change between them. Refer to: http://www.sierrachart.com/index.php?page=doc/StudyCollections.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-08 19:53:59] |
Yes i see what you say and thanks for that ... but is there a way to asking to 2 different shortcut keys at each of the study collections so i can quickly change between them? (i edited the previous post at the time of your last answer so you may not have seen it) for example : at Analysis TAB -----> there is an option which can hide all of the studies in the chart. I would like to hide half of the studies in the chart ... meaning select which of the stydies i whanna hide with one click. Also I already have assinged a shortcut key to hide/enable all the stydies in the chart. Date Time Of Last Edit: 2018-05-08 20:01:35
[2018-05-09 08:01:02] |
The only thing that we are willing to do is to add keyboard shortcut keys, for the Study Collections assigned to control bar buttons.
[2018-05-09 16:47:57] |
that would be great!
[2018-05-13 07:15:02] |
@sstfrederik - Posts: 404 |
Maybe this can help you. Its in the freebundle https://www.simplesystemtrading.com/hide-studies/ |
