Date/Time: Mon, 13 May 2024 08:21:28 +0000
Using a VPS with Windows2012
View Count: 861
[2018-05-08 07:34:47] |
User298259 - Posts: 1 |
I want to use a signal service on a VPS with Windows 2012. The software loads and receives data ok but the signals are not generated when the chartbook is loaded. The signals work ok on Windows10. Am I missing something on the 2012?
[2018-05-08 07:51:26] |
This definitely does not have anything to do with the operating system. You need to contact the service providing these signals about the issue.
