Date/Time: Sun, 12 May 2024 04:23:58 +0000
Keyboard Shortcut to Change to 5-10 Reversal Chart ?
View Count: 664
[2018-05-08 04:55:56] |
Acro - Posts: 436 |
Hi, Trying to work out the quickest way to change from a 1 minute chart to a 5-10 Reversal chart just by using the keyboard. I have tried "5-10rv" and "5,10rv" with no joy. Is there a way without going to chart settings ? Thanks |
[2018-05-08 18:57:44] |
This ability is not supported in the current release. Only the first parameter for the Reversal Bar is supported (the Reversal Amount). We have added the ability to enter both values for the Reversal Bar from the keyboard, it will be available in the next release. The documentation on how to change bar period type using the keyboard can be found here: Changing Chart Bars Period: Fast Changing by Keyboard Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
