Date/Time: Mon, 29 Apr 2024 16:44:47 +0000
[Locked] - Time and Sales Alerts Have a Problem in Version 1738.
View Count: 1777
[2018-05-07 18:49:59] |
In version 1738 there is a problem with time and sales alerts which can lead to an exception and instability in Sierra Chart. This has been resolved in the latest prerelease. Update with Help >> Download Prerelease if you are using Time and Sales alerts: Software Download: Fast Update This issue arises due to changes with text strings in Sierra Chart to migrate away from Microsoft code. It has to do with a particular variable parameter function where it is not easy to catch this kind of problem. We are working on a solution to avoid this kind of issue in the future. This is not the first time this has happened and that is why we are working on a definitive permanent solution. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-14 03:47:31
