Date/Time: Mon, 13 May 2024 09:54:05 +0000
Horizontal grid based on a specific prince with an increment of X ticks
View Count: 911
[2018-05-06 11:47:22] |
User849476 - Posts: 17 |
Hi Team, Is there a way to add an Horizontal grid based on a specific price with an increment of X ticks above and bellow this price ? Thanks and regards, Date Time Of Last Edit: 2018-05-06 11:48:03
[2018-05-06 22:09:33] |
Probably would be best to use the Horizontal Lines study for this: https://www.sierrachart.com//index.php?page=doc/StudiesReference.php&ID=113&Name=Horizontal_Lines Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-05-08 10:17:52] |
Hi There, I tried this study but not sure it's working the way i want so let me wrap up my need. I actually want to set a specific price like the open for exemple and from this price add automatically horizontal lines every 10 ticks above and below this open. Do you thinks this is possible with this study or shall i use another one ? Thanks and regards, Date Time Of Last Edit: 2018-05-08 11:24:44
[2018-05-08 18:55:16] |
What we think would be best to do is to use the Line study and then use multiple instances of the Study Subgraph Add study for each of the horizontal lines.: Study Subgraph Add Line You can use a positive value to add and a negative value to subtract. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-08 18:57:03
