Date/Time: Sun, 19 May 2024 06:25:06 +0000
VbP for TPO Chart issue
View Count: 1466
[2018-05-04 06:59:02] |
User106180 - Posts: 88 |
With the 'VbP for TPO Chart' study, I sometimes get the volume bars at either end extending past the TPO. Please see the 7th last chart in the first link (low of the day), and 5th & 6th last days in the second link (highs of the days). Is this an issue with the study or my settings? Thank you http://www.sierrachart.com/image.php?Image=1525417007665.png http://www.sierrachart.com/image.php?Image=1525434132369.png Date Time Of Last Edit: 2018-05-04 11:45:01
[2018-05-04 16:50:46] |
We need to get that one chart from you so we can test this. Here are instructions to attach it: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-04 16:52:13
[2018-05-11 02:12:13] |
Chartbook attached. Thank you.
Private File |
[2018-05-13 02:24:50] |
The basic problem is that the Volume Bar Calculation Method is not compatible with the Bid Volume Ask Volume Coloring Method. These inputs need to be set to correspond with each other when the coloring is based on diagonal calculations. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-13 02:26:56
