Date/Time: Sun, 26 May 2024 13:41:26 +0000
CFE - Rithmic
View Count: 882
[2018-05-03 19:39:35] |
User531665 - Posts: 4 |
Hi, Can you add the following symbols please? I added CFE for $21/mo. as a datafeed. I had asked for VI and you guys did add that and I do see that symbol. Are you able to add the rest please? Please see list below. I have Rithmic 01-US from AMP Futures as my normal data. BG (Bitcoin futures) N2 (10-year T-Note VIX) Q6 (S&P 100 VIX) R3 (Nasdaq 100 VIX) VA (DJIA VIX) VN (Gold ETF VIX) W1 (Crude Oil ETF VIX) W3 (Euro FX VIX) Y8 (Brazil ETF VIX) Y9 ( Emerging markets VIX) Thank you so much. Under "Futures (Non-tradable) I do see the VI futures you guys added. I don't see the others yet. Thanks! |
[2018-05-04 04:31:12] |
Yes, we can do this, but the symbols are not going to be listed under "Futures (Non-tradable)". They will be listed under the standard categories they normally are listed under. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
