Date/Time: Sun, 19 May 2024 00:03:13 +0000
alert question
View Count: 676
[2018-05-03 18:55:08] |
Glenn Infinity - Posts: 103 |
I have two studies on screen which take up a lot of space. They are Cumulative Delta bars – Volume, Cumulative delta bars – up/down tick volume. I track Divergence. I.e. when they step out of line with each other ( when one makes a new high/low, and the other doesn’t, and vice, versa) we then have divergence. Can this be set as an alert study within Sierra? Hope the above makes sense. |
[2018-05-03 19:22:59] |
You can try to figure this out but this is definitely something which is not in the scope of our support to provide a formula for this. The Divergence Detector study Sierra Chart has does not calculate the divergence between two studies. Only in comparison to the main price graph. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-05-03 19:23:32
