Date/Time: Sun, 19 May 2024 02:02:07 +0000
[User Discussion] - Quote Board Missing Information
View Count: 666
[2018-05-03 06:12:33] |
User164231 - Posts: 278 |
Hi Support, What can I do to repopulate yesterday's US Stock closing numbers on my quote board? My computer did a restart and then everything is gone. Thanks. |
Missing information.jpg / V - Attached On 2018-05-03 06:09:49 UTC - Size: 178.85 KB - 288 views |
[2018-05-03 06:23:39] |
We see you are using the Interactive Brokers trading service, so you will need to connect Sierra Chart to Trader Workstation.
