Date/Time: Wed, 15 May 2024 23:09:27 +0000
importing studies
View Count: 1221
[2018-04-28 19:08:06] |
User895936 - Posts: 4 |
Hi I have copied the study in the charts section. but when i go to studes and try to ad the study it does not show in the list. i have folloewd all the steps shown in the trhread posted above but the study which i importe dis not showing for some reason. can you please help me solve this isssue? thank you khalid |
[2018-04-29 03:51:09] |
Select Help >> About within Sierra Chart. Does it say 32 or 64 bit? What is the name of the DLL file which contains the studies ? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-29 03:51:16
[2018-04-29 05:00:10] |
t does not say 32 or 64bit. name of the file is amirN.dll. Thank you |
[2018-04-29 07:05:44] |
Exit from Sierra Chart and run Sierra Chart again using the shortcut on your desktop without _64 in it.
