Date/Time: Thu, 16 May 2024 09:30:23 +0000
acsil study subgraph writing into file
View Count: 1659
[2018-04-28 10:17:25] |
User30743 - Posts: 364 |
hello, would like to ask if there is a function for writing values of a custom-based study into a .TXT file (and also for reading from it). i have build a simple study but after each recalculation, the subgraphs dissapear so i dont see the history. i guess i need to somehow save the values into a file (TXT or other type?) so that the data will not get lost. can you give me a hint of how to do that? is there any function for it or a documentation please |
[2018-04-29 07:58:54] |
this only holds data from a main chart, not from a home-made custom study that i need
Date Time Of Last Edit: 2018-04-29 07:59:04
[2018-04-30 19:46:00] |
From within the study, you can use the function sc.WriteBarAndStudyDataToFile() as described here: sc.WriteBarAndStudyDataToFile() From outside the study, you can use the study Write Bar and Study Data to File as described here: Write Bar and Study Data To File Also, refer to: http://www.cplusplus.com/reference/cstdio/ Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-30 19:47:06
