Date/Time: Tue, 14 May 2024 21:33:21 +0000
Please define nan(ind)
View Count: 1379
[2018-04-27 13:44:09] |
jsoviero - Posts: 84 |
I have a study in region 3 that is blank with the "nan(ind) phrase in bold. what does nan(ind) signify? Thanks for your guidance. |
[2018-04-27 18:36:57] |
What study is this? That value is a standard value from the floating-point calculation as performed by the CPU indicating that the result is not a number. Usually this is the result of a division by zero. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
