Date/Time: Tue, 14 May 2024 10:17:17 +0000
[Programming Help] - Disabling auto trade multiple times per day
View Count: 1091
[2018-04-27 13:26:35] |
User739131 - Posts: 27 |
Hi, I was wondering if there is a way to disable auto trading multiple times per day. For instance if I wanted to disable from 9:00 to 9:30, 10:30 to 11:00, and 11:30 to 12:00 can this be done? Thanks very much for your help. MJ |
[2018-04-27 13:44:28] |
Sawtooth - Posts: 3996 |
Have a look at this link: https://www.sierrachart.com/index.php?page=doc/SpreadsheetExampleFormulasAndUsage.php#DisableTradingOutsideOfRegularTradingHoursAnd2HoursMidday |
[2018-04-27 13:47:34] |
Hi Tom, Thank you for the reply. I currently am using the disable mid day time code. However this only allows me to disable trading once per day. I can't seem to figure out how to start and stop multiple times per day. |
[2018-04-27 13:57:30] |
The second half of that formula is an AND statement inside of the OR statement. Simply add another AND statement inside the OR.
[2018-04-27 14:09:27] |
Ok great thanks!
[2018-04-27 15:26:07] |
Ok so I've entered the code and I am getting #NUM! in cell J28. Not sure what this means.
[2018-04-27 15:27:52] |
This is the code. =AND(J8 = 0, OR(OR(FRACTIME(J41) < TIMEVALUE("08:30:00"), FRACTIME(J41) > TIMEVALUE("14:29:00")), AND(FRACTIME(J41) > TIMEVALUE("08:59:59"), FRACTIME(J41) < TIMEVALUE("09:30:00")), AND(FRACTIME(J41) > TIMEVALUE("010:29:59"), FRACTIME(J41) < TIMEVALUE("11:00:00")), AND(FRACTIME(J41) > TIMEVALUE("11:29:59"), FRACTIME(J41) < TIMEVALUE("12:00:00")))) |
[2018-04-27 15:33:05] |
TIMEVALUE("010:29:59") needs to be TIMEVALUE("10:29:59")
[2018-04-27 15:44:24] |
Stupid typo. I swear I'm going blind. Thanks very much! |
