Date/Time: Tue, 14 May 2024 02:59:27 +0000
CQG // RITHMICS
View Count: 658
[2018-04-26 19:14:51] |
User00111 - Posts: 111 |
Please inform me if possible to use Sierra with two accounts for trading. I have an account with CQG and CTS. I installed in pc two Sierra. I want to do is when I place an order on Sierra/CQG, it automatically repeats it on the Sierra/CTS This is possible ? |
[2018-04-26 21:28:39] |
No, this is not supported but eventually we will support duplicating trades among multiple trading accounts which are with the same connected service. But you can use CQG and CTS at the same time in separate instances of Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-26 21:29:03
