Date/Time: Tue, 14 May 2024 06:42:09 +0000
[User Discussion] - SC Fast Update with Sub Instances can be a little confusing
View Count: 675
[2018-04-26 11:15:26] |
CarlRostron - Posts: 80 |
On updating (Fast Update) my Main SC, causing some confusion to me and probably other users is that I currently need to close my Sub instance manually before doing the Update. Otherwise, I am getting into a position where the Main Insance installs and reopens on the new version, but my sub instamce shows an older version in the Window Frame. This just happened. Might it be better if SC's closes all sub instances programmatically before doing the update so that when it re-opens, the sub instance opens as well with the correct version number in the Window Frame? |
[2018-04-27 04:45:18] |
Acro - Posts: 436 |
I noticed this too. What I do is make sure all sub instances are now closed before using Fast Update. That way when I reopen them they are the latest version |
