Date/Time: Mon, 21 Sep 2026 10:46:38 +0000
Trial Version and paid version issue
View Count: 944
[2018-04-25 17:03:41]
User536105 - Posts: 36
I am a trading mentor and recently I discovered that the number bars data (such as volume, max delta, min delta and delta) from my students are different from mine. Later I then discovered they were using trial version of sierra chart. May I ask is this the actual reason that made us different?
Thank you.
[2018-04-25 17:53:14]
No it has nothing to do with whether the account is on a trial or not.
Make sure all copies of Sierra Chart you are doing comparisons with, are set for a tick by tick data configuration:
This is essential. Make sure you follow the step to re-download the data.
Date Time Of Last Edit: 2018-04-25 17:54:02
[2018-04-25 18:02:07]
Yes, they have already set this correctly. Is there any other reason which caused the issue? All of my students discovered this problem and they are using the trial version.
[2018-04-25 18:22:58]
Post an image of each of the charts where you see a difference, by following these instructions here:
There could be different reasons which relate to the times of the chart bars and the source of the data.
[2018-04-25 18:58:06]
Thanks. I have got the answer from your company.
