Date/Time: Mon, 21 Sep 2026 10:45:47 +0000
Color Numbers bars bid and ask similar to last coloring on DOM
View Count: 1043
| [2018-04-25 02:21:32] |
| phlapjack - Posts: 7 |
On the Dom you can color the "Trade DOM last traded recent Ask/Bid Volume Background" when a trade fires on the bid or ask. When you set up Numbers bars BidxAsk is there a way to do the same thing so as your looking at the numbers bars you can spot the flow easier?
| [2018-04-25 18:25:55] |
There are various color settings for Numbers Bars. Refer to the relevant documentation here: Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-25 18:26:59
