Date/Time: Sat, 18 May 2024 15:40:25 +0000
TPO Chart - Single Prints
View Count: 1669
[2018-04-24 17:15:28] |
nicktrader - Posts: 665 |
As you can see in the attached file NT8 offers the option to highlight SinglePrints. SC offers the option: "Extend Singles" (in this example with a white line). The position of the lines I do not understand - but okay, this it not my question. Is it possible to highlight single prints - as marked with a white ellipse - similiar to NT8? |
SC vs NT TPO.png / V - Attached On 2018-04-24 17:14:17 UTC - Size: 39.9 KB - 654 views |
[2018-04-24 19:57:51] |
We suppose we could add this option but it should be quite obvious where there are single prints, if the only thing you are interested in is just a simply a highlight.
[2018-04-25 04:22:15] |
Yes, "only" a simple colored highlight option. Would be great Txs |
[2018-05-05 05:08:03] |
I thought you were adding this option, although it seems obvious. Why is this option available in NT? Adding this option is a peace of cake for you. The color highlighting would emphasize it even more. |
[2018-05-21 09:56:57] |
Rassitude - Posts: 33 |
Indeed if this is something simple to add, it would be useful. Thanks |
