Date/Time: Wed, 15 May 2024 12:45:18 +0000
CANNOT CHART TRADE FROM SECOND ISNTANCE
View Count: 595
[2018-04-24 10:08:47] |
michelh - Posts: 159 |
Hi Sierra, I have recently began to use a 2nd instance of sierra chart. I chart trade and use bracket orders from the chart. today, I put in an order from the chart in the second instance. It was rejected; the log reads: DTC client #1. Sierra Chart. 127.0.0.1 | New order rejected. DTC client order ID: 958.123 | 2018-04-24 05:57:07 * DTC client #1. Sierra Chart. 127.0.0.1 | New order rejected. DTC client order ID: 959.224 | 2018-04-24 05:57:07 * DTC client #1. Sierra Chart. 127.0.0.1 | New order rejected. DTC client order ID: 960.325 | 2018-04-24 05:57:07 * Interactive Brokers | Received position. Trade Account: U7064208. Symbol: CC-201807-NYBOT | 2018-04-24 06:01:20 Interactive Brokers | Received position. Trade Account: U7064208. Symbol: CC-201807-NYBOT | 2018-04-24 06:04:20 Sim Trade is OFF. But this a real nuisance. So I went into IB and did the bracket order manually. I could not have done this in a fast market. Then, the orders appeared on the chart. I tried to modify the profit taker by moving in on the chart and it wouldnt let me do it - I had chart trade mode on. So I had back into IB and modify. I am visual so I need to be able to enter from the second instance right off the screen with thanks |
[2018-04-24 12:31:23] |
Relevant message: Interactive Brokers order update (Order reject). Info: Non-simulated Trade Account (Uxxxx) cannot be used with Trade Simulation Mode. Internal Order ID: 958. Service Order ID: (none). Symbol: CC-201807-NYBOT | 2018-04-24 05:57:07 * Refer to: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Using the Correct Trade Account (Rejections Related to Simulation Mode) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-24 12:32:13
