Date/Time: Sat, 27 Apr 2024 14:38:28 +0000
[Programming Help] - Attached Orders
View Count: 662
[2018-04-23 10:54:39] |
User39772 - Posts: 311 |
When I use attached orders like: NewOrder.Stop1Offset = Value1; NewOrder.Target1Offset = Value2; Other exit conditions that could happen between Value1 and Value2 and are verified via my code are ignored. Also Exit Arrown are not drawn in the Chart, only entry arrows. It would help to get some hints here if it is possible to have these attached orders, Stop and/or Target and additional other exit criterieons. |
[2018-04-23 18:30:22] |
Make sure you have this automated trade variable set to True: Automated Trading Management: CancelAllWorkingOrdersOnExit Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-24 10:39:31] |
Thank you that helped for attached orders. I have a similar problem now with non attached trailing orders like: s_SCNewOrder NewOrder; NewOrder.OrderQuantity = 2; NewOrder.OrderType = SCT_ORDERTYPE_TRAILING_STOP; NewOrder.Price1 = sc.BaseData[SC_LAST][sc.Index] - 10*sc.TickSize; My BuyExit/SellExit conditions seem to have a lower priority than the trailing stop and are not executed. Is there a similar solution available or do I have tu use an attached trailing stop to solve that ? |
