Date/Time: Mon, 29 Apr 2024 05:15:03 +0000
Cummulated bid ask vol ratio
View Count: 766
[2018-04-22 05:05:43] |
User358040 - Posts: 21 |
Hy Would it be possible to add some cummulative bid ask vol ratio for a stock for specific time frame? when i see a stock for 10 days I see the bid ask vol ratio but not per day but cumulated for the specific time frame? on day 2 I see day 1+2 etc. Kind regards |
[2018-04-23 18:54:56] |
You can use this study: Cumulative Sum of Study And base it on the Bid Ask Volume Ratio study. You can then adjust the starting Date in the chart to what you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
