Date/Time: Mon, 20 May 2024 23:07:22 +0000
Forgotten option
View Count: 553
[2018-04-21 15:57:03] |
user8888 - Posts: 159 |
you might have forgotten to add the 'vertical scale' option in the secondary menu. cheers |
vertical-scale.PNG / V - Attached On 2018-04-21 15:54:31 UTC - Size: 19.67 KB - 216 views |
[2018-04-21 21:58:25] |
This will be added. We can also see the controls are overlapping and that will be corrected as well.
