Date/Time: Sun, 05 May 2024 04:09:52 +0000
Swing High and Low indicator shows incorrect price
View Count: 664
[2018-04-20 12:26:10] |
User644165 - Posts: 25 |
Hi Guys, On FDAX futures the minimum price increment is 0.5 EUR, but my Swing High and Low indicator is showing 12534.4 as the daily low which is obviously false. Is there a way to fix it? http://prntscr.com/j7t4x3 Thank you. |
[2018-04-20 18:39:07] |
Set the Arrow Offset as Percentage Input with that study to 0. Refer to: Swing High and Low Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
