Date/Time: Tue, 10 Nov 2026 17:40:59 +0000
How do i edit historical intraday data?
View Count: 857
| [2018-04-19 14:01:10] |
| User71961 - Posts: 144 |
There is a single price that i want to modify from a historical data file...but i don't know which file has the data, or how to edit the file. is there a help page on this? |
| [2018-04-19 18:49:49] |
The easiest way to do this is to use the option under Edit >> Edit/Download Data - Intraday Chart. You can find the documentation for this here: Edit Menu Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-19 18:50:46
