Date/Time: Sat, 04 May 2024 08:13:39 +0000
just one order filled, how to set 3 step trailing stop like below?
View Count: 8006
[2018-04-19 11:42:17] |
Diana - Posts: 42 |
1. when Profit 70tick trailing 30tick 2.when Profit100tick trailing 20tick 3.when Profit120tick trailing 15tick that mean I can tighten my stop when the profit go up. You've give me the link to learn and I can not do this. Pls refer to my pictures. PLEASE note that just one order for the attached orders. |
360截图20180419084432843.jpg / V - Attached On 2018-04-19 11:42:07 UTC - Size: 114.3 KB - 543 views |
[2018-04-19 20:00:40] |
You need to set the OCO Group for the Target order to All OCO Groups. Refer to: Attached Orders: OCO Group (Group) And on the Main tab of the trade window, make sure the order quantity is set to 3. Otherwise, it looks as though the settings are correct. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-19 20:00:48
[2018-04-20 02:59:36] |
Diana - Posts: 42 |
just 1 order,pls. when my profit get ..... when my profit get ..... when my profit get ..... there are 3 steps for just ONE position. tks. I can do it in NinjaTrader,and I definitely think can do it in sierra chart |
[2018-04-20 05:00:24] |
OK we now understand. Since you had 3 Stop orders we thought that you wanted an order quantity of 3, still would be considered one Position, and just one target with different Stops. We apologize for the misunderstanding. What you want to do is not exactly supported. The closest would be utilizing this order type: Triggered Step Trailing Stop: Order Types: Triggered Step Trailing Stop So you can only use one Stop order and it should be a Triggered Step Trailing Stop. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-20 05:01:04
[2018-04-20 06:35:21] |
Zdislav - Posts: 73 |
User126222: What you want can only be achieved either via spreadsheet study or through ACSIL which I find more comfortable to work with. Z. |
