Date/Time: Sun, 19 May 2024 21:54:19 +0000
ExchangeRejectCode 2060 / 2061
View Count: 792
[2018-04-18 19:30:48] |
User942837 - Posts: 108 |
Kindly review attached sreenshots. Example, when I am facing this issue: I get long a price and it goes up 3 ticks and is trading there, I go and place a sell order and it rejects it instead of putting me in the queue. It works fine if I place it above, it goes as a limit sell, or below, but when I place it at the current price being filled, it rejects it as a stop Can you kindly provide a solution to this as it is happening quite often. Thank you |
Attachment Deleted. Private File |
[2018-04-18 22:15:21] |
Those error messages ultimately originate from the exchange and are rejections of a Stop order based on its price. It should be clear what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-18 22:29:35] |
Yes of course I understand what the problem is but when this happens, order is always entered @ last price on DOM, so I am not sure why it is being sent as a stop order.
[2018-04-19 00:14:05] |
OK, this has to do with the Chart DOM configuration here: Global Trade Settings Windows: Chart DOM Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-04-20 07:00:48] |
I am attaching the settings. Can you have a look please as this is happening all the time. I am simply trying to exit trades on limit at last price in the following scenarios: 1) enter long on limit at current printing price without rejecting order 2) Get short a limit order at current printing price without rejecting order 3) put in a sell limit below current price that is being printed, without executing order until hit, not filled higher 4) same for the opposite for long Date Time Of Last Edit: 2018-04-20 07:01:24
unnamed.png / V - Attached On 2018-04-20 06:58:01 UTC - Size: 50.36 KB - 290 views |
