Date/Time: Tue, 30 Apr 2024 01:06:15 +0000
Ideální připojení datového kanálu, výměnu a Sierra C
View Count: 1123
[2018-04-18 17:49:23] |
User74285 - Posts: 3 |
Dear Sierra Chart, I am asking you for an ideal connection to the data feed, exchange fee, and Sierra Chart licensing. I currently have Sierra Chart with Advanced Features (Service Package 5) of 21.78 USD / month and I use the Interactive Brokers Trading Service externally. 1x Data Feed For 10 Real-time Symbols: 1st connection 25 USD / month, 1x Exchange CME with Market Depth for Nonprofessional Trading Accounts 5.25 USD / month • (GBLX) Nasdaq 100 E-Mini (NQ) • (GBLX) S & P 500 E-Mini (ES) • (GBLX) Russell 2000 E-Mini (QR) 1x Exchange CBOT with Market Depth for Nonprofessional Trading Accounts 5.25 USD / month • (CBOTM) Dow Indu 30 E-Mini (YM) 1x SC instance for Futures Symbols Total 21.78 + 25 + 5.25 (CBOTM (YM) 5.25)) = 52.03 USD / (YM 57.28 USD) / month. In the case of the 10 symbol limit, when using both stock exchanges, and futures or index exchanges, then the real-time symbol limit is as follows: Equities will have a limit of 9 real-time symbols. And futures and indices will have a limit of 4 symbols. To this report, I would like to add the possibility to trade (Systematically, AOS) separate / individual Shares of the S & P 100 index. Is it possible to trade manually and systematically / AOS) within one Sierra Chart instance with multiple Instances / Copies? Or need to pay for additional connections, 2nd connection 20 USD / month For 100 Real-time Symbols for each S & P 100 Share Index? Symbol Limits: If you have both stock options and futures or index exchanges, then the real-time symbol limit is 125 symbols and it works as follows: Equities have a limit of 90 real-time symbols and futures and indices have a limit of 35 real-time symbols for a total of 125. There is one exception to what is described above. Stock Data from the Sierra Chart Exchange Data Feed uses a different network connection compared to Futures and Index data. This is done for performance reasons. Therefore, it is possible to receive Futures and Index data from the Sierra Chart Exchange Data Feed in one instance of the Sierra Chart and stock data from the Sierra Chart Exchange Data Feed using another instance of the Sierra Chart. Or pay U.S. Equities (NYSE, NASDAQ) 10.50 USD / month? Intraday Tick data is also provided for US stocks (NYSE and NASDAQ)? And historical tick Bid / Ask data for Autobacktest Stock - For example AAPL max historical download data? You can use multiple Sierra Chart Instances / Copies and multiple TWS / IB accounts. Respectively, I would like to divide the trading capital. Allocation of capital to individual Trading Strategies. Is it necessary to allocate another SC account? I would like to use only one SC account and several Instances / copies of everything? On your site, I've read about Sierra Chart and Interactive Brokers, see "Please therefore carefully consider whether the use of Sierra Chart with Interactive Brokers is appropriate." So your recommendation? Sierra Chart is very good, stable and now also in 64-bit version. However, in the case of systematic trading / AOS - do you recommend leasing a software / VPS server for the Sierra Chart? The problem is High Latency Trading - Czech Republic >> Chicago? My speedtest Download 19.77 Mbit / s - Upload 15.09 Mbit / s - PING 6 ms. Sierra Chart Refresh Rate |
[2018-04-19 20:07:45] |
Is it possible to trade manually and systematically / AOS) within one Sierra Chart instance with multiple Instances / Copies? Yes you can.But you definitely want to change the number of real-time symbols to 100 instead of 10. You can do that here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures Or pay U.S. Equities (NYSE, NASDAQ) 10.50 USD / month? Yes, you should activate this exchange.Intraday Tick data is also provided for US stocks (NYSE and NASDAQ)? Yes for at least 6-9 months back. Prior to this to data will be in 10 second units. And historical tick Bid / Ask data for Autobacktest Stock - For example AAPL max historical download data? Yes this will be available for at least 6 months back.I would like to use only one SC account and several Instances / copies of everything? Yes. You just need one account. That is all. You do not need another one.On your site, I've read about Sierra Chart and Interactive Brokers, see "Please therefore carefully consider whether the use of Sierra Chart with Interactive Brokers is appropriate." So your recommendation? In your case we recommend staying with Interactive Brokers.Sierra Chart is very good, stable and now also in 64-bit version. However, in the case of systematic trading / AOS - do you recommend leasing a software / VPS server for the Sierra Chart? Yes you can do this. Might be a good idea.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-04-19 20:09:34
