Date/Time: Fri, 03 May 2024 08:37:43 +0000
Are there differences between SC+LMAX and LMAX only?
View Count: 592
[2018-04-18 07:44:54] |
User25311 - Posts: 30 |
Is there a difference in commissions if you work with Sierra Chart and LMAX and if you work directly with LMAX? And in execution? I have special conditions agreed with LMAX, and I do not want them to be harmed by using a routing with Sierra Chart. Neither in terms of commissions nor in terms of execution. Can I be sure this won't affect me? Thank you. |
[2018-04-18 08:59:20] |
To our knowledge this should not make a difference but you really have to check with LMAX on this just to be sure. We do not receive any commissions from LMAX. So we would expect that the commissions you receive to remain the same.
