Date/Time: Sat, 27 Apr 2024 17:06:23 +0000
EUREX_error
View Count: 558
[2018-04-17 10:13:23] |
User850017 - Posts: 41 |
Helo, I would like to set datafeed EUREX but It does not work. I put error screen.
Bez názvu.png / V - Attached On 2018-04-17 10:13:09 UTC - Size: 93.34 KB - 267 views |
[2018-04-17 10:25:35] |
We are checking on this for you but we are not going to find out until the morning in Chicago.
[2018-04-17 19:12:06] |
Sierra Chart - Max - Posts: 5597 |
Your account is marked as a professional account, so you need to activate the Eurex Professional Feed, including Market Depth exchange option.
Sierra Chart Support Date Time Of Last Edit: 2018-04-17 19:13:01
