Date/Time: Sun, 05 May 2024 13:04:03 +0000
Understanding DTC
View Count: 1002
[2018-04-15 18:30:42] |
ycomp - Posts: 274 |
So using DTC, anyone (programmer) can create a server side application that can be used to supply data to a Sierra Chart installation?
[2018-04-16 04:23:46] |
Yes. Refer to: Data and Trading Communications (DTC) Protocol Test Client Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
