Date/Time: Sun, 05 May 2024 15:12:15 +0000
Swing High Low
View Count: 923
[2018-04-14 10:25:04] |
User39772 - Posts: 311 |
Is the cpp code for this study available or could you make it available ?
[2018-04-14 11:07:56] |
Yes. Refer to: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
