Date/Time: Fri, 03 May 2024 07:18:40 +0000
[Programming Help] - renko size
View Count: 2054
[2018-04-14 02:01:07] |
Yamin2000 - Posts: 31 |
Hi I am trying to set the renko size as ATR number for example the ATR for GBPJPY is .542.how do i make each box size .542.I am using trading view and i can make each box set by any number and it works fine. does renko in SR works different? |
Attachment Deleted. |
[2018-04-17 21:48:32] |
User44052 - Posts: 34 |
Hi Yamin. Try the other way around. Keep the tick size in decimals and then use the number you want in the Setting field under Renko bar in ticks. For example tick size = 0.001 and 542 in Renko setting. Or tick size = 0.0001 then the Renko setting would be 5420 I hope this helps. |
[2018-04-17 22:00:41] |
thanks m8
[2018-04-17 22:12:17] |
i tried it does not look like tradingview chart
[2018-05-31 15:01:45] |
User523480 - Posts: 18 |
Could the engineers from Sierra release this type of charts for Sierra? ATR based Renko chart with wicks ? Thanks |
[2018-10-19 14:05:05] |
User61576 - Posts: 418 |
+1
