Date/Time: Tue, 10 Nov 2026 17:28:59 +0000
SC Data software update
View Count: 1495
| [2018-04-12 03:48:18] |
| User768651 - Posts: 2 |
I don't know why recently my account cannot access to software update. The one I am using at the office is 1716 while my home is 1713. I recall whenever I update the current version, it will show download and update successful. Now it only asks me to close but nothing updated. Can you pls help me to sort that out ? |
| [2018-04-12 03:52:53] |
| User553714 - Posts: 186 |
Unable to Update Sierra Chart Had the same problem a few days ago, Just run the downloader from the SierraChart folder instead of clicking on "download current version" from inside the software. |
| [2018-04-12 04:02:55] |
This issue is described here along with a solution: Unable to Update Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
