Date/Time: Thu, 16 May 2024 10:29:59 +0000
Order Rejected
View Count: 713
[2018-04-10 16:04:53] |
User894467 - Posts: 19 |
I am using a new instance to execute trades. I am successful in so doing until after a time the orders are rejected and I have to create a new chart from the file menu which means the chart has to be rebuilt from scratch. Is there some method by which I can re establish trading on a previously working chart? attached are log messages. thanks |
Private File |
[2018-04-10 18:25:31] |
Refer to this section here about this: Using DTC Server for Data and Trading in Another Sierra Chart Instance: Using the Correct Trade Account (Rejections Related to Simulation Mode) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
