Date/Time: Wed, 15 May 2024 03:30:48 +0000
TPO - adding the time of day to each bar at the bottom
View Count: 730
[2018-04-10 13:27:50] |
dd45 - Posts: 41 |
I attached a screen shot of my current TPO chart. I would like at the bottom of the chart to show what time of day each bar is. My chart is 30 minutes so It shoudl say for A period 9:30, B period 10, C period 10:30, etc. This is how it is on most charts. How do I enable that for the TPO chart? Thanks
timechart.jpg / V - Attached On 2018-04-10 13:25:41 UTC - Size: 147.3 KB - 330 views |
[2018-04-10 18:03:31] |
This is not supported for TPO Profile Charts even when you display the subperiods in their own column.
[2018-04-10 18:45:33] |
dd45 - Posts: 41 |
In the following picture that I found on this site, it does seem to show time periods at the bottom https://www.sierrachart.com/images/TPOVolProfileCharts_img11.png At the bottom where it says 11-9 and then for 11-10 it shows times. I think that is what I am looking to add. |
[2018-04-11 18:50:47] |
We will update that chart image. It is very old.
