Date/Time: Wed, 01 May 2024 06:08:10 +0000
Live trading test during Trial period and multiple broker connections
View Count: 684
[2018-04-09 15:11:52] |
SuperDriveGuy - Posts: 5 |
Hi, I plan to use Sierra Chart for execution, mainly for your risk management feature Global Profit/Loss Management and then perhaps for charting in the future. I have a couple of questions based on this. Please be so kind as to answer them 1. I have an account with FXCM, can I try out trading within this trial period? as the main purpose is to test the Risk Management feature, which can be tested with real trades. I have anecdotal evidence that this works with futures, just wanted confirmation for CfDs. Do I need to intimate FXCM about the change to Sierra from Ninja? settings are different etc? 2. Can I connect to multiple providers/brokers at the same time e.g. FXCM for execution and IQFEED/Kinetick for Data? Thanks |
[2018-04-09 18:49:51] |
1. Yes. However, you have to go through the instructions here which is not a fast process: https://www.sierrachart.com/index.php?page=doc/FXCMTrading.php#Setup Going through that process is not recommended just for testing. 2. Yes. Refer to: Using Multiple Data and Trading Services at the Same Time But instead of using IQ Feed we recommend using the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
