Date/Time: Sat, 04 May 2024 19:18:06 +0000
Special Bracket Order
View Count: 651
[2018-04-09 12:07:53] |
User130100 - Posts: 7 |
Hello, I was wondering whether ot not it was possible to integrate a second entry in a position at a cheaper price level by bracket order; For instance, it would look like this: lmt Buy second lmt Buy at -4 Ticks [Second Entry] Stop Sell at -6 Tick [Both Positions - Flatten] I'll also attach an image to visualize what I mean. I looked at the target input options, but was only capable to find options for "targets" and my "stops" - however this additional entry resembles none of both. Thanks in advance. |
SIERRA.PNG / V - Attached On 2018-04-09 12:06:30 UTC - Size: 92.15 KB - 286 views Attachment Deleted. |
[2018-04-09 18:10:14] |
Have a look at the Scale In functionality: Attached Orders: Scaling In Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
